Bulletproof Suspension Lift Kit 2009-2013 Ford F-150 12''
Quick Overview
Fits 2009-2013 Ford F-150 2WD/4WD regular cab, double cab, crew cab regular or long bed
All parts are covered in high quality gloss black powder coat (color upgrades available)
All Bulletproof manufactured parts are covered by a lifetime transferable warranty.
No welding required our kit is designed to be entirely "bolt on".
Improved ride and handling from factory.
Factory wheel base and track maintained.
Our Bulletproof kit features unique one piece drop cage, steering linkage, differential, drop down, sway bar and A-arm drop downs and our Uni-ball A-arm system comes standard as do Stainless Steel braided brake lines! Two shocks are required for this system and we offer standard shocks or we can recommend Fox Racing Shox equipment all the way around for the ultimate set up. Complete instructions with photos and hardware kit labeled for each step accompany this project for ease of assembly. We here at Bulletproof Suspension Inc. recommend rear Atlas Leaf springs (quoted separately) to round out this heavy duty lift system. When your done, go anywhere you want with no problem as your truck will be equipped to go the distance no matter what you throw on it.We here at Bulletproof Suspension Inc. know that your vehicle is important to you, and we've designed our F150 lift kit so that your truck can be returned to stock. There is no need to cut, remove or modify anything as most of our competitors do. Keeping your critical factory components intact is essential to the value of your truck. Anything less isn't just right.
nick_bp
02-21-2019 02:05 PM
nick_bp
01-08-2014 02:54 PM
nick_bp
05-22-2013 11:29 AM
nick_bp
Vehicles for Sale
04-11-2013 11:58 AM
