Help 95 302fi
Old 03-14-2008 | 09:35 AM
harley1's Avatar
Default Help 95 302fi
Hi i have a 95 f-150 302 fully restored. I have replaced all sensors. I get a 111 clear code. But when i start it even when it's up to temp it accelerates to very fast idle and the engine light flashes 2to four times then after a few seconds it decelerates and feels like it almost shuts down then runs great till you shut it off and restart it. Can anyone teel what would cause that i'm going crazy. THANKS, lOU
Old 04-26-2008 | 09:06 AM
mford89's Avatar
Default RE: Help 95 302fi
I also have 1995 f150 that will do the same thing but not every time. have you performed KOER self test? Have you performed any engine modifcations? perform the engine running test if you have not yet. I performed KOEO test and got a111. I then performed KOER test and got a code for knock sensor change not detected on WOT snap. I performed pin point test per ford PCED. The tests lead to replace pcm but I have not done it yet on my truck.
joebug1956
02-18-2009 10:03 AM
Quick Reply: Help 95 302fi
