Rear Window Leak
Old 03-13-2008 | 01:13 AM
automech's Avatar
Default Rear Window Leak
I have a Ford f150 98 and the rear window has been leaking for some while now. When it leaks, it runs down the back glass, but lately I noticed that it also fills my dome light as well. How do I remove the back glass to check/reseal it, or could it be my 3rd brake light leaking?
Old 04-01-2008 | 11:30 PM
rollingthunder's Avatar
Default RE: Rear Window Leak
Reg cab? If your dome light is right next to the 3rd brake light that would be my guess. Other than that I don't see how it could get there without seeing significant damage to your headliner as well.
Old 10-07-2010 | 06:06 AM
truckboy's Avatar
Banned
does it have weather stripping? if so replace it. if not, put a little bit of silicone around it, but do a half decent job or otherwise it will show.
Old 10-10-2010 | 11:59 PM
Nikole's Avatar
Thumbs up Rear Window Leak
Car glass includes windscreens, side and rear windows, and glass panel roofs on a vehicle. Side windows can be either fixed or be raised and lowered by depressing a button (power window) or switch or using a hand-turned crank. The power moon roof, a transparent, retractable sunroof, may be considered as an extension of the power window concept. Some vehicles include sun blinds for rear and rear side windows.
Old 10-14-2010 | 10:38 PM
rjohnson67's Avatar
I had this problem with my old 2000 F-150, and it was the brake light. Fixed it with silicone. I think if i'm not mistaken, a lot of those f-150s had that problem.
guinell1
02-24-2011 04:40 PM
med3939
09-08-2008 06:47 PM
jcbst12
8
07-11-2008 08:46 AM
shadow
07-08-2008 08:30 PM
timbo
03-29-2006 08:16 PM
Quick Reply: Rear Window Leak
