Starting Problem
Old 02-27-2007 | 03:46 PM
billnb's Avatar
Default Starting Problem
I have a 97 F150 4.6 automatic 4x4. When I try to start the engine the starter grinds like it's not engaging the flywheel unless you pull back on the shifter then it fires right up. It had issues with the shifter tube, the tube was broken, the screws at the end of the tube were loose, and the bushings were wore out. I fixed these and that took the play out of the shifter, but I still have to pull back on the shifter to avoid the grinding and to get the engine to start. Any ideas?
Old 03-09-2007 | 07:23 PM
farqy's Avatar
Default RE: Starting Problem
I have a friend with a Chevy that keeps having to replace starters, because they either die or don't engage properly. Even techs at auto electric places cannot seem to get it right. Something to do with shims, and they can never seem to shim it properly. When you "pull back" on the shifter, are you actually shifting the transmission, or just leaning against the stop that keeps you from shifting out of Park? It seems that if the shifter position is changing the engagement of the starter, it might be a transmission problem. Maybe there is an alignment issue with the tranny.
gmchevy
01-13-2007 08:02 PM
nathanfox83
12-26-2006 09:25 PM
the dude27
12-09-2006 03:32 AM
dankoos
10-07-2006 10:42 AM
TonyBoneKhang
09-19-2005 11:35 PM
