Water in Cab!
Water in Cab!
I have a leak on my 03 F-130. A big enough leak that it filled up the channel above the rocker panel where the wiring passes to the rear of the cab under the floormat. Further inspection has revealed the water appears to be coming through the firewall just above the passenger side floormat. There is a plastic piece that looks like it passes through the firewall on the left side of the passenger floor pan possibly going to the fresh air plenum. This piece has a foam gasket around it that is sopping wet. Has anyone else experienced this problem? The truck has never seen mud so I assume nothings clogged.
Thanks for any light you can shed.
In2Trux
04-19-2015 09:50 PM
FLARAIDER
05-10-2011 05:17 PM
codman14
07-09-2010 11:07 AM
silverado99_1
06-04-2008 05:09 AM
