Ford General Tech Ford tech talk within.
How to Replace a Fuel Filter in a Ford Explorer
Old 02-17-2013 | 09:51 PM
hellozaizai's Avatar
Banned
Default How to Replace a Fuel Filter in a Ford Explorer
Keep the fuel system in your Ford Explorer in optimal condition by replacing the fuel filter every 30,000 to 40,000 miles. A clean fuel filter means clean fuel injectors and a clean fuel pressure regulator. Follow the instructions below to replace the filter on a Ford Explorer in under 45 minutes.
Things You'll Need:
Hoist
Wrench
Quick-connect separator tool set
New fuel filter
Instructions:
1. Begin by disconnecting the battery ground cable. Relieve the fuel system pressure by removing the fuel pump relay and then starting the engine. Let it idle until it stalls. Then, crank the engine for about 5 seconds to make sure the pressure has been released. Turn the ignition off.
2. Raise the vehicle and locate the fuel filter on the passenger side, under the door near the front wheel well. It is behind a curved shield called the fuel filter heat shield. Remove the bolts from that shield. Then, remove the nuts and the fuel filter shield.
3. Disconnect the quick release and spring lock couplings. Remove the fuel filter and any fuel line caps. Put the new filter in place and connect the quick-release and spring-lock couplings. Make sure you install the fuel pump relay. Reinstall the fuel filter heat shield and torque the bolts to 15 foot-pounds.
4. Lower the vehicle and reconnect the battery ground cable. Start your Ford Explorer, check for leaks, and fix any you find.
view more:.
Old 02-24-2013 | 09:54 PM
Banned
hope it can help u and good luck
Old 03-03-2013 | 09:52 PM
Banned
what do you think about it
Old 03-04-2013 | 12:17 AM
Very usefull info
Keep up the great work
Very much appreciated
rcravincase
06-08-2011 05:30 PM
Worf
Ford How-To's and Tutorials
04-14-2010 01:36 AM
Nat LMMC Ct
Vehicles for Sale
06-06-2007 11:54 AM
kkamann
03-26-2007 04:29 PM
leerics911
Vehicles for Sale
08-01-2006 05:11 PM
Quick Reply: How to Replace a Fuel Filter in a Ford Explorer
