Ford General Tech Ford tech talk within.
replacing timing gears 4.9-300-6
Old 08-18-2007 | 07:28 PM
stormy76's Avatar
Default replacing timing gears 4.9-300-6
first time on this site, & hope someone can help!!!! am replacing timing gears on a1996 f150 4.0-300c.i. 6cyl. tried using a gear puller to remove cam gear, but as the d--n gear is is plastic or whatever, part of gear is on the ground & rest is still on end of the cam& i am lost as what to do now!!!! any suggestions would be greatly appreciated
Thanks, stormy76
Old 08-19-2007 | 07:44 AM
Argon's Avatar
Default RE: replacing timing gears 4.9-300-6
The manual says to press it off,which involves removing the cam (Aghhh)///..can you whittle it down to just the metal collar,and split it with a chisel?..I've done that on some engines
Old 08-19-2007 | 09:33 AM
stormy76's Avatar
that is about the only option left now. only problem is I can't remove the fan. large nut is siezed to the water pump, & would have to replace the whole unit, which I could do. am doing this for a friend, it's his work truck, & has limited funds, but you gotta do what you gotta do!!!
Thanks, stormy[:@]
Old 08-19-2007 | 06:46 PM
Argon's Avatar
yeah,they make wrench kits for those fans that are powered by an air hammer....you may find 1 for rent
max77713
04-22-2008 12:52 AM
jcbst12
9
12-03-2007 01:25 PM
stormy76
08-18-2007 06:52 PM
MrLM7
04-11-2007 10:27 AM
JSMConstruction
04-04-2005 03:24 AM
