1989 F350 2 WD 5.8L- Fuel Filter Location???
Old 12-11-2007 | 10:21 PM
oneforthemoney2007's Avatar
Default 1989 F350 2 WD 5.8L- Fuel Filter Location???
I just bought a 1989 ford f350 crew cab 2 WD with a 5.8L engine. It starts fine and runs fine but when I come to a stop it will idle fine for 5-10 seconds and then start cutting out like it is going to die. Once I get under way again it seems to run fine while moving down the road. No misfiring or anything. I am thinking it is starving out of fuel at an idle. I purchased a $10 in-line fuel filter but do not see an existing filter along the frame rail under driver side area. I found the fuel pump and followed the lines but cannot find thefilter location. Where should I be looking?
Old 12-12-2007 | 05:23 AM
Argon's Avatar
Default RE: 1989 F350 2 WD 5.8L- Fuel Filter Location???
its fuel injected?..its either on the frame...or in the tank
scoyote
03-08-2012 07:54 PM
cbileske
07-28-2011 01:24 PM
dgwbusiness
05-22-2008 10:25 PM
tworivers
10-13-2007 07:24 AM
TBigLug
Vehicles for Sale
02-08-2007 05:19 PM
Quick Reply: 1989 F350 2 WD 5.8L- Fuel Filter Location???
