1990 F250 ignition system stuck in start mode
Old 05-04-2011 | 12:44 PM
Kale's Avatar
Default 1990 F250 ignition system stuck in start mode
1990 F250, 5.8L, 4x4, auto.
Ignition system stuck in start mode, past spring-loaded key position even with key cylinder removed. When battery is connected, starter engages/turns engine/won't disengage, stereo comes on.
Tried tapping solenoid in case of stuck contacts - no change.
Thanks
Old 05-05-2011 | 09:35 AM
geomath's Avatar
Talking self starter
Sounds like there might be a short in the wiring harness or maybe this truck is Christine's great comeback performance.
Old 03-15-2012 | 07:49 PM
mikeyt5060's Avatar
Default stuck ignition
Try unplugging the harness from ignition switch under dash on steering collom then hook up battery and see what happens.
Old 03-16-2012 | 01:47 PM
Kale's Avatar
Ignition switch was no good. 2nd one. Thanks
navy_smitty29
04-17-2009 06:30 AM
chevyrules
04-14-2009 11:31 AM
dmccartyfan
39
04-07-2009 11:28 PM
dmccartyfan
03-08-2009 09:08 AM
webbch
02-08-2007 12:54 PM
Quick Reply: 1990 F250 ignition system stuck in start mode
