2000 gmc sonoma 4.3 miss under heavy exceleration
I have a 2000 sonoma 4.3 with 75000 miles it set for about 2 years i have replaced alot of parts and it ran very well for a while but just recently i have had a check engine light scan tool said co2 sensor rich in all banks i know that changing the o2 sensors wont necesarlly fix it because there are alot of things that can cause this problem. the first thing i noticed was my oil pressure dropping at idle very low almost 8 psi then it will come back i was wodering maybe the oil pan filter but the most recent problem is under heavy exceleration it will hesitate until 2000\2500 rpms then after that is fine under normal driving it operates fine i am curious if any one has dealt with this or has any ideas i am new to the forums
Sorry Sonoma
Many of our regular members have met new members like yourself.
Sign up
First post is their truck problem.
One of our members will reply with a solution.
New members second post will be a thank you. then never to return again.
Normally With good social forum educate. A new member will visit the New Member Area and read some of the stickies across the top of the home pg.
Sign up
Meternerd
03-06-2010 12:01 PM
bizkit132
04-30-2007 10:54 PM
