4.10 limited slip
4.10 limited slip
I'm haveing some problems with my 02 350 dually. The rear end is staying locked in I think. Can anybody give me any idea on how to check. I did lift the back up an both tire would spin the same way, and if I'm right they should.
If you feel one side hopping when you make a tight turn then it is staying locked. The easiest way to tell is go to a parking lot where there is enough room to make a tight circle if it is locked you will definitely know it.
stopspazinout
16
07-20-2007 08:00 AM
