97 F-350 tune up questions
Old 09-18-2008 | 10:00 AM
Keizer's Avatar
Default 97 F-350 tune up questions
Hi everyone! I have a 97 Ford F-350 with 89,000 miles. Although it runs fine, I have never done a tune up on it. I have noticed when I use it for towing, that it lacks a little power that it once had. I would like to do a tune up now, and have bought all the necessary components. I have plugs, plug wires, rotor, cap, PCV valve, fuel filter, air filter, and serpentine belt.
My questions: Where is the PCV valve located? I did a quick glance on the valve covers, but didn't see anything that stood out.
Also, how do I release the fuel pressure safely when changing the fuel filter? I remember changing the filter on my F-250 years ago, and I had to release the fuel pressure first. Problem is, I don't recall the steps.
Also I was told by a friend of mine to pull the hoses off the throttle body, open the butterfly valves and clean out the throttle body. Carb clean and a bottle brush. Disconnect the battery and let it sit for ten minutes. I'm not sure exactly what is in there to clean. Anyone have a pic of this?
Any other suggestions??
Thanks alot!!
DeuceBag
09-11-2011 02:41 PM
JoshLikesBeer
05-27-2011 04:11 PM
fr8train
06-07-2010 08:58 PM
67c10
01-24-2008 05:12 PM
