99 7.3L Oil Pressure Problem. HELP!
Old 04-10-2011 | 08:29 PM
KTMMDG's Avatar
Default 99 7.3L Oil Pressure Problem. HELP!
Hey let me first start off as, this is A 1999 Ford F350 7.3Liter Diesel Truck.
275,000Miles I am the second Owner, The original Owner bought this truck Brand new. I have all of his service Records.
He kept this truck clean and serviced it every 3,000miles.
I know he hauled and used this truck as it was meant to be used. things done on the truck have been.- 1inch Blocks. 35inch All terrain Tires. Banks Power Stinger Plus System. Custom Automatic Transmission with Suncoast Converter, TransGo Tugger Kit, Alto Clutch Packs, Mag-Hytech Pan. 456 gear Ratio.
The High Pressure Oil Pump was replaced at 175,000miles
all Ford Recalled items have been replaced.
other then that nothing else has been done.
Owned it for a while then the Problem started.
Fact 1. At idle the Dash gauge would sometimes flicker and the lite would come on. this would (return to normal) when the RPM was at or higher the 1,000RPM.
Fact 2. my Dad and I put a mechanical gauge on it. Oil Pressure at idle read Zero. at 2,000RPM it still read Zero.
Fact 3. We Diagnosed that, it could be the Oil pressure regulator valve. or the Engine Oil Pump.
Fact 4. Replaced the regulator valve unit. and Replaced the Engine Oil Pump with a Melling engine oil pump.
Fact 5. Put the Mechanical gauge back on. At cold idle read 50psi then slowly came down to 25psi at 2,000RPM read 50psi and held.
Fact 6. (took her up the hill. came back) At Hot idle read Zero. at 2,000RPM read just 25psi.
where's the Oil Going?!? although Replacing the Oil Pump and regulator valve unit made a big difference it's still not where it should be. The Engine is not Knocking it sounds great. so my Dad and I don't think its the main Bearings.
what else could it be? anywhere else the oil could be squeezing by? what I'm I missing here?
Old 04-11-2011 | 08:35 AM
Worf's Avatar
Does the Check engin light come on at all ?
Old 04-11-2011 | 12:42 PM
KTMMDG's Avatar
No it does not. only the Gauge and the Oil light are affected inside the cab.
Old 04-15-2011 | 05:26 PM
KTMMDG's Avatar
Alright so, I checked the pickup tube just in case and it seems to be working properly. I haven't pulled the Valve covers yet but will probably be doing so soon. Turns out My dad has a scanner, we are looking for it when we find it we'll scan and see what turns up.
I put a mechanical gauge on where the filter housing unit is.
Here's the difference between checking it there and the reservoir.
Reservoir, Hot idle = 0psi. 2,000rpm = 25psi.
Filter housing unit, Hot idle = 0psi. 2,000rpm = 45psi.
I'm confused?
I've been told it could be the rocker arms or maybe the oil galley plugs?
any thoughts?
Old 05-01-2011 | 01:22 AM
KTMMDG's Avatar
Discovered the problem, A Piston oiler Broke off/Fell down into the bottom of the Oil pan.
Old 07-21-2011 | 12:46 AM
ashleyrms22's Avatar
that's going to be fun to replace. That'll teach you to be jumping those train tracks at 70 MPH...
PennSt8
8
02-14-2012 09:46 AM
acsudberry21
01-18-2012 10:46 AM
roadkingmi
04-18-2009 11:13 AM
caleb_daniel91
01-20-2008 10:58 PM
Utah88
02-07-2007 01:34 AM
Quick Reply: 99 7.3L Oil Pressure Problem. HELP!
