99 F250 - valve problem - 5.4 V8 Triton
Old 05-05-2010 | 08:53 AM
johnh's Avatar
Default 99 F250 - valve problem - 5.4 V8 Triton
I have this truck & doesn't idle very well. Guy before me told me it had a compression test & a valve was damaged. Want to do my own test. No signs of plugs or wires. Are they under the valve cover ? Can I tell the bad valve - int or exh - in comp test ? How to set valves after if I remove head to replace valve ? Thanks
Old 05-05-2010 | 05:01 PM
Worf's Avatar
you have to pull off each coil to find the spark plugs. The plugs sit under the coils. A service manual will show you how to set the valves if you need to replace them.
Old 05-06-2010 | 08:55 AM
johnh's Avatar
Yes, is there a link that would have a FREE download or someyhing to even look at even just to copy down with a pencil - as far as doing a valve set on this 5.4L Triton >>>>> Thank You.
klr650goldwing
02-11-2010 11:24 AM
Eastfrisian
11-05-2008 04:30 AM
gilti2629
Vehicles for Sale
08-22-2008 10:29 PM
mrhaney
Vehicles for Sale
08-01-2006 12:07 AM
fastercaster
12-19-2005 05:47 PM
Quick Reply: 99 F250 - valve problem - 5.4 V8 Triton
