ABS & Integrated Brake Controller
Old 03-26-2012 | 11:21 AM
bunkered's Avatar
Default ABS & Integrated Brake Controller
For all you 2007 and earlier Super Duty owners with a factory-installed Integrated Brake Controller you may have a major potential safety issue. I recently had an ABS warning light appear on the cluster and to my amazement when I pressed on my brake pedal I had no indicators on the Integrated Brake Controller. When I grabbed it and squeezed manually I had full braking to the Trailer Braking System but off the brake pedal there was nothing. Upon further investigation I was able to determine that when the ABS warning light is on the power to the Trailer Braking System is cut from 12 volts to 3 volts. Clearly not enough power to properly engage that system. This "design" was confirmed by Ford and all they had to say was that it was "operating to spec". This design was apparently changed in 2008 so that the Integrated Brake Controller did not get wired through the ABS computer. Unfortunately Ford is standing pat that it is operating as designed and is not seemingly concerned that the design itself may be flawed.
gerktj
08-28-2011 11:34 PM
redbaron
07-07-2010 07:42 PM
BG CHEVY
09-03-2009 09:44 PM
sceptre74
10-31-2007 10:58 AM
Quick Reply: ABS & Integrated Brake Controller
