Bulletproof Suspension Lift Kit 2005-2013 Ford F250/F350 12"
Quick Overview
Fits 2005-2013 F250/F350 Super Duty 4WD Regular, Double & Crew Cab short/long bed.
All parts are covered in high quality gloss black powder coat (color upgrades available).
All Bulletproof manufactured parts are covered by a lifetime transferable warranty.
No welding required our kit is designed to be entirely "bolt on".
Improved ride and handling from factory.
Factory wheel base and track maintained.
No drive shaft modifications required.
Bulletproof Suspension Inc. has designed a Ford F250/F350 12" Suspension System with the best engineering, design and superior quality Bulletproof Suspension Inc is renowned for. Bulletproof Suspension has been the bench mark for the industry by making the best Ford F250/F350 lift kit on the market. All components are made of A36 steel plate 1/4" thick or thicker and heavy wall D.O.M. (drawn over mandrel) seamless steel tubing. We use continuous seam welding with our exclusive cross bead internal rosette reinforced construction to insure every Bulletproof suspension lift is "Bulletproof".
Our Bulletprooff kit features Panhard drop down and Four-Link system, sway bar links and dual steering stabilizer. Two shocks, two front coil-overs and two steering stabilizers are required for this system and we recommend Fox Racing Shocks equipment all the way around. Complete instructions with photos and hardware kit labeled for each step accompany this project for ease of assembly. We here at Bulletproof Suspension Inc. recommend Atlas Leaf springs (quoted separately) to round out this heavy duty lift system. When you're done go anywhere you want with no problem, as your truck will be equipped to go to the distance no matter what you throw at it.
We here at Bulletproof Suspension Inc. don't cut corners and set you up right in the beginning. Ford F250/F350 Bulletproof Suspension lift system and upper control arms and off-set a-arms for more caster gain are included as well. We here at Bulletproof Suspension Inc. know that your vehicle is important to you and we designed our Ford F250/F350 kit so that your truck can be returned to stock. There is no need to cut, remove or modify anything as most of our competitors do. Keeping your critical factory components intact is essential to the value of your truck. Anything less isn't just right. Like we said, your search is over, come over to Bulletproof Suspension Inc. lift system.
To find more information please visit:
or call us on
909-389-0444
or call us on
909-389-0444
nick_bp
01-08-2014 02:54 PM
nick_bp
08-28-2013 05:58 PM
nick_bp
Vehicles for Sale
04-11-2013 11:58 AM
