Dead battery on 2006 F350 Diesel
My F350 lets me down once in a while. It has happened 2-3 times. For no reason at all the batterys are flat enough I need a jump. Have charged them up and had them tested and they are ok. has Ford had an issue with electrical? The same has happened to my sons 2007.
Battery
I have four 2005 F-250's and one '05 F-350, and one '04 E-350, and two '05 F-150's in my fleet and have had battery issues with all but one. The one problem I have found is that the terminal connections are extreemly weak. The thin/flimsy clamp around the posts will corrode fast. I have started cleaning, cleaning meaning removing and using a wire brush, every oil change and have resolved most of the problems.
4chevytrucks
12-27-2016 07:26 AM
AZ03silverado
09-28-2009 07:59 PM
