New (to me) '93 F250 - What mainenence?
Old 07-23-2010 | 12:46 AM
kazslo's Avatar
Default New (to me) '93 F250 - What mainenence?
I recently bought a 1993 F250 automatic with a 351 gasoline engine. I can tell just by looking at the dipstick it wasn't taken care of all that much by its previous owner. I've already done the following:
  • New Air Filter
  • Cleaned air intake
  • Drained and replaced coolant
  • Fixed bad harmonic balancer
  • Replaced wippers
  • Checked for any OBD-I codes
  • Filled power stearing fluid
  • Checked brakes/fluid
  • Replaced spark plugs/wires
My next move is to change the engine oil and differential fluid. I don't have the manual or any sticker which says what oil to use, and ford.com support only goes from 1996. How much oil does the engine take (I'd imagine 6 qts), and which oil (I am in a warm climate)? Also, I have read to use a 75W-90 for the differential, but all I find in the store is SAE 90 for manual transmittions or ATF fluid. Would the SAE 90 suffice or do I need to look further?
Once I get through with that, I plan to clean the throttle body out. Anything else that I should look over before a current problem becomes worse?
THANKS!
Todd0060
04-17-2012 02:15 PM
jpilgrim
06-30-2011 10:57 AM
Axeman
04-06-2011 02:30 PM
PolarisRider
06-26-2010 09:27 AM
