replacing a 1994 f350 rear wheel cylinder
Old 02-05-2011 | 09:39 AM
Evan Housewright's Avatar
Default replacing a 1994 f350 rear wheel cylinder
How do I replace the right rear wheel cylinder on a 1994 f350 with dual wheels?
Old 02-05-2011 | 04:17 PM
Worf's Avatar
Replacing Wheel Cylinders:
  1. Jack up the car and place jack stands under the frame to support the car. NEVER work on a car supported by the jack alone.
  2. Remove the tires, brake drums and brake shoes. If the brake shoes are soaked with brake fluid, replace them. Mark the drum to the hub so you can replace it the way it was.
  3. Spray the hydraulic line and fitting with CRC 5-56 or a similar rust penetration spray. You might want to do this first so it has time to work. Put your drip pan underneath it to catch any over flow and brake fluid.
  4. Using the appropriate size line wrench, loosen the hydraulic fitting. I recommend a line wrench because they are designed specifically for working on hydraulic fittings. A standard wrench will work, but the chances of ruining the fitting are greater. Don't try to turn it out in one shot, work it back and forth and spray some CRC 5-56 on it as you work it out. This will keep the line from twisting as you remove the fitting.
  5. Before you take the fitting off completely, remove the two mounting bolts. Then take the fitting off by hand and remove the wheel cylinder. You do this to avoid any possibility of bending the line. As soon as the fitting is off, brake fluid will start to run out. Plug the end of the line with a suitable plug, I use a piece of vacuum line with a bolt in one end.
  6. Now that the fitting is off and the old wheel cylinder is out, you can install the new one.
  7. Start the fitting in the new wheel cylinder and turn it is as far as possible by hand. Then mount it on the backing plate and install and tighten the mounting bolts. Don't go crazy here; you don't want to snap the bolts off.
  8. Once the mounting bolts are tight, tighten the hydraulic fitting.
Old 02-06-2011 | 10:13 AM
thanks worf
Old 02-06-2011 | 03:47 PM
Worf's Avatar
welcome
stusharp84
02-18-2012 12:53 PM
BubbaRay
08-11-2010 12:03 AM
silent_snipe
03-14-2008 08:51 PM
justin.chamberlain
10-26-2007 01:33 PM
discoinferno65
10-12-2006 04:52 AM
Quick Reply: replacing a 1994 f350 rear wheel cylinder
