What size engine????
Old 07-14-2009 | 04:53 PM
Stinger444's Avatar
Default What size engine????
Hey everyone, I currently have a 2000 F-150 with the 4.6l v8. I want more power to tow a larger trailer easier. I don't like the new F-150's so I decided to just go for a used F-250. I'm looking at a 2005-07 truck which would fit my budget. I was looking into the 6.0 strokers but I've heard some bad things about them. I'm pulling a 6'x12' enclosed trailer fully loaded across country which I'd like to do comfortably. Please give some suggestions!!! Thanks. -Mike
Old 07-14-2009 | 05:01 PM
I'd say find a 7.3 Powerstroke, or switch brands
Old 07-14-2009 | 08:18 PM
bradsharp's Avatar
Member
i would think a 7.3 would be a bit overkill for a 6x12. i would say a 6.0L would be fine unless you have a really heavy load. but the 7.3 would definatly make it the easiest. also there is the triton v10. my cousins pulls a 5th wheel camper all the time and he has never had a single problem with it to my knowledge.
Old 07-16-2009 | 03:56 PM
slimburns's Avatar
I have a friend that tows a 10,000 lb 5th wheel camper w/ the V10 he has no issue what so ever, other than stopping at every gas station...
Old 07-31-2009 | 03:57 PM
bradsharp's Avatar
Member
i think he stays at 11 miles to the gallon even with the heavy load it doesn't really cause the engine much strain. and with a 32 gallon tank u could go over 300 miles on one tank. though with a power stroke it would be a little more fuel efficient but more costly to fill up when u do eventually have to stop.
Old 08-01-2009 | 04:53 AM
Diesel is cheaper than gas here... Gas is $2.49, Diesel is $2.32
Old 08-01-2009 | 07:09 AM
GMCTRUCKS's Avatar
Member
Get a Dodge with a Cummins or a HD GM truck gas has HP but diesil has the pulling power that you need.
Old 08-16-2009 | 04:24 PM
7.3monster's Avatar
Well if your looking for an earlier model pickup, 250 size, i would suggest looking at the 07 models becuase those 6l have had the bugs worked out of them and are slightly more reliable then the 03 to 06 engines. i have a 2000 7.3 and i love it. Although i tow a slighty heavy load (01 1840 Case Skid Loader) my milage on it is aswome, i would guess i get anywhere from 20 to 25 miles to the gallon on the highway and 16 to 18 in the city i live in. altough you can always improve gas milage by watching your driving styles. but if you want to stay gas, and milage really isnt a factor, a 250 with the 5.4 in it should do you alright, i would also look into investing in a trailor brake system if you already havent
Old 08-17-2009 | 04:19 PM
bradsharp's Avatar
Member
5.4L would be bad on gas if he has the trailor fully loaded he might as well go for a diesel. but if he isn't going to have a major load on it a 5.4L could work.
Man In Black
09-10-2011 08:28 PM
ArmyAviator
04-18-2010 12:53 PM
bigboy23
10-13-2009 06:46 PM
montero91
12-07-2005 02:19 PM
bzackrie
08-14-2005 03:12 PM
