Wind
Old 03-20-2012 | 03:04 PM
grester1966's Avatar
Default Wind
I have a 2012 F-250 King Ranch 4x4. Are you supposed to hear the wind whistling around the doors going down the highway? Sometimes the Sync system can't hear me correctly because of the noise. Seems kind of odd that you pay $50K for a truck and they can't engineer an airtight door...
Old 05-15-2012 | 04:39 PM
JAFFB's Avatar
My 2011 F250 does the same thing, it sounds like a horn blast at speeds of 70 plus. Not sure where its coming from. anyone have any ideas?
Old 05-16-2012 | 04:21 PM
Worf's Avatar
Make sure the door is closed all the way and that the seal around the door is not damaged, and that the window is up tight
Old 05-17-2012 | 09:59 AM
johntaps's Avatar
Former Sponsor
Post Wind
Check out the ends of door seals for tight fitting on the frame. If sound is coming even after doing it , then its better to install second set of rubber door seals to bridge any gaps.
gmsuv
8
09-16-2008 08:08 AM
ropechoker
09-09-2007 03:05 PM
SouthBayZ71
07-27-2007 08:21 AM
jaxspellinar
07-24-2007 07:33 PM
abtanner
06-08-2004 10:29 AM
Quick Reply: Wind
