Ford Ranger/ Mazda B-Series Discuss the Ford Ranger and it's sister, the Mazda B-series here.
My Truck Sputtering
Old 07-18-2005 | 01:11 PM
bagged_b2600's Avatar
Default My Truck Sputtering
I have a 1991 Mazda B2600. I'm having some engine problems and needed some advice. Every time I accelerate, the car just kinda sputters. It goes slow as hell. It doesn't get up to go. I changed the spark plug wires. Any idea what it could be.
Old 09-13-2005 | 02:00 AM
hybrid_malibu's Avatar
Default RE: My Truck Sputtering
Could be several things related to fuel, air and spark. Try changing out the fuel filter and having the injectors cleaned or replaced. Changing plugs could also help. Clean out the TB with some TB cleaner. Have you checked you Thermostat? If a thermo is stuck open, it can cause your truck to NOT go into closed loop mode. This allowing the engines emissions and fuel delivery systems to work properly. Your truck has to operate at a certain temp for everything to work. Your O2 sensor has to hit a certain temp to go into closed loop. Sorry to throw out so much, but it truly can be anything.
Old 11-25-2013 | 08:06 PM
BleedTheFreak97's Avatar
Play with your timing that's always fun.
Old 11-26-2013 | 06:35 AM
poncho62's Avatar
Thread is from 2005....truck is probably made into a Prius by now
Old 11-26-2013 | 11:30 AM
HaHaHa That's awesome Poncho
john-i
10-12-2009 12:13 AM
tayoz00
04-20-2008 01:18 PM
sierraon22
08-21-2007 05:59 AM
nluoma
03-11-2007 09:50 PM
nluoma
02-17-2006 08:22 PM
