1997 Chevy 2500 Brake switch knowledge needed!
Old 02-03-2007 | 11:29 PM
chillinday2day's Avatar
Default 1997 Chevy 2500 Brake switch knowledge needed!
Recently I had replaced the front braking system on my 1997 Chevy Cheyenne 2500. Then a few days later I noticed my brake lights weren't working. So I narrowed it down to the brake switch. Now does anyone know how you adjust these or where I can go to get the diagrams. It works now as I just stuck my hand up there and kindof moved things around. But sometimes it goes out and im wondering if when I had the brake system bleed it damaged the switch or through it out of adjustment. Thanks
Old 02-25-2007 | 03:37 PM
00ShortBoxChevy's Avatar
Default RE: 1997 Chevy 2500 Brake switch knowledge needed!
You may have a broken wire or a bad switch. If the switch was out of adjustment your brake lights would be on all the time.
Old 02-25-2007 | 05:40 PM
Argon's Avatar
No real adjustment on the 97...does the 3rd lite work,or is it all crap-canned?
Old 02-27-2007 | 12:01 AM
99z71325ci's Avatar
yeah i had the opposite prolem a few weeks ago. mine stayed on. i think its just loose try disconnecting it clean the connectors and tighten the bolts you should be fine.
mikeyd
01-28-2015 09:30 PM
Kohen
10-21-2012 06:38 PM
ALOD
12-14-2011 07:11 PM
chevyrules
16
04-04-2007 01:47 AM
dark_preacher
10-10-2006 12:35 AM
