1999.5 (new body style) Z71 Tranny issues
Old 11-25-2012 | 07:26 PM
danano's Avatar
Default 1999.5 (new body style) Z71 Tranny issues
driving about 75 MPH in OD today on hwy I got into the throttle and tranny downshifted to pass. I felt a "stumble" in tranny and immediately lost OD and the RPM was 1000 higher than before this issue. It seemed as though I was now in regular drive. When I ran into some stop and go traffic on hwy it became apparent that the trans is not shifting to higher gears like it was previous to this situation. (does go into higher gear but RPM goes much higher than used to)
Once I got home I intended to back into the driveway but realized I no longer have reverse, all other drive positions engage ok except as noted above that the shift pattern has changed. I checked the fluid, not low or missing. Is there an electronic shift module that possibly has gone bad that might cause these conditions or something else besides trans itself?
Trans has approx 183K on it, serviced as should be, never abused but pulls boat trailer and 4 wheelers frequently but <2000lbs
Just looking for ideas/your experience
Last edited by danano; 11-25-2012 at 09:53 PM. Reason: GMC Sierra extended cab 4WD manual shift 5.3L SLE
Old 11-26-2012 | 04:14 PM
danano's Avatar
For those interested in what this issue turned out to be - the Sun Shell stripped out causing lose of reverse, 2nd gear and/or overdrive. In shop being rebuilt now
Old 11-26-2012 | 10:23 PM
RustyFordLover's Avatar
Yea, that is a common problem with the chevy trucks.
Old 11-27-2012 | 11:06 AM
Wow Interesting. Thanks for sharing your tranni issue. What transmission is it?
Old 11-28-2012 | 03:10 PM
danano's Avatar
Tranny is the 4L60E - hooked to the 5.3 V8. I have to say it has been a reliable drivetrain until I hit the 185K mark.
I just replaced the engine in August with brand new GM factory 5.3 (not a reman) and now the tranny should be like new....so I expect another 180K plus out of it. LOL...
Old 11-28-2012 | 04:33 PM
Well I'm glad it all worked out for you. Hope you can come back and hang out with us and possibly help others
Old 11-28-2012 | 11:39 PM
My truck just hit 100,000, and i have about 92,000 left on the warranty, so I should be good to go.
Old 11-29-2012 | 07:46 AM
danano's Avatar
I appreciate the replies to my post. I'll post a pic or two of the Sierra when I get it back from the shop. I have had it since 17K miles on it, Been a great vehicle, but as you know, anything mechanical is subject to breakage.
1999.5 GMC Sierra, extended cab Z71 w/manual shift xfer case, K&N air intake, stainless exhaust with nice low/moderate rumble, leveled suspension, matching color topper on bed, spray lined bed, tailgate and top rails.
Old 01-02-2013 | 08:18 AM
Diesel Dan's Avatar
Atleast when the reaction shell strips out you are not left in tennis shoe mode.
We lost ours in the driveway when going into reverse. It was a '99 S10 Blazer w/140K on it. I pulled the transmission, replaced the shell and affected gaskets and reassembled. Still going with 181K+.
Friend of mine waited one day to trade his '97 Z71 in and that one day is when the sun shell stripped out and cost him almost 2K off the trade.
Old 01-06-2013 | 05:08 AM
Same thing happened to my dad.
jason0779
08-25-2010 11:56 AM
MIZZOU1
05-29-2009 09:49 AM
Pelicandivebomb
05-07-2009 06:32 PM
cork
12-07-2007 07:04 PM
argomez75
08-02-2007 02:30 AM
