2000 silverado tansmission
Hey Guys,
I need some help.
I have a 2000 silverado Z-71. The problem is the transmission will not go into low gear.
It will go low 4wd.
and it seems overdrive won't kick in when it is in 2wd
Could this be only a sensor? Please email back with any help.
Thanks, Dale
I need some help.
It will go low 4wd.
Thanks, Dale
RE: 2000 silverado tansmission
It actslike it starts in 2nd gear. and when I go down the road and go from 2 to 1 nothing happens and when I start in d in seems to start in 2nd., but 4 low works great.
I had a similar problem a year ago with the gauges and transmission.
But I could disconnect battery and it would fix it.
Hey,
Here is what is happening. The service engine light is on but motor runs fine.
The ABS light come off and on
and the transmissions will not shift right.
Do you think this a computer issue?
Thanks, Dale
Thanks, Dale
No but the computer might tell what the problem is and more than likely if the engine is running fine and the light is on is a trans issue you have a trans control unit (TCU). my light was on because of a shift solenoid and it wouldnt shift right and wile on the highway it would slip in and out of overdrive. when it was cold it wouldnt go into 2nd.
okay, I will take it to Advance Auto parts and get it checked out in the morning..
I will then put whats codes it is calling out on here tomorrow,
Where can you find what the codes are?
THanks for all your help...
Ron
06-11-2006 04:53 AM
