4L60E Transmission Problems on Sonoma
Old 02-18-2008 | 10:24 AM
rkr29kracing's Avatar
Default 4L60E Transmission Problems on Sonoma
Hello
I have a 1997 Sonoma 4 cylinder with a 4L60E. A few weeks back I noticed tranny fluid in the driveway, the source was a bad pan gasket. I checked the fluid level, but I noticed it was foaming up too much to get a reading. I changed the pan gasket and filter, and refilled the trans with the proper amount of fluid. When I went to check it again, it was still very foamy.
I took it out for a drive, and it shifts fine, however, it wont downshift into first gear. No matter how hard I accelerate, it wont kick down. I had to make a couple stops along the way, and each time I shut the truck down, and restarted it, it would go into first. But after driving a mile or so, no first gear. I tried it again while coasting at about 20mph, shut the truck down, put it in neutral and restarted it. It would go into first gear fine at that point.
I don't know much about transmissions, but I assume the foamy fluid if causing the malfunction. I am not sure what shutting it down has to do with it shifting into gear. Anyone seem this, or have any advice?
Old 02-18-2008 | 11:32 AM
Argon's Avatar
Default RE: 4L60E Transmission Problems on Sonoma
are you sure its not overfull?..that will cause your foam
Old 02-18-2008 | 11:47 AM
I don't think it is overfilled. I made sure to get the right amount back in it after I pulled the pan. It was hard to check though, because as soon as I started it, it foamed up.
Old 02-18-2008 | 03:03 PM
Argon's Avatar
something wenmt wrong if it did not do this before...i';d take the pan off and look at the filter...make sure it has a seal...and not 2 seals holding it in...it may be sucking air at that seal...o-ring cut or something
2KSilverado1500
01-24-2012 01:28 AM
2KSilverado1500
01-23-2012 08:10 PM
Rescue35
09-19-2010 12:36 AM
GMCTRUCKS
08-31-2009 05:33 PM
gmworker
08-29-2008 08:26 PM
Quick Reply: 4L60E Transmission Problems on Sonoma
