4L80E trans
Old 03-16-2010 | 12:22 PM
rcbraun's Avatar
Default 4L80E trans
Hi all, new to this forum. I'll help where I can, but right now I have a problem. My 95 K2500 4L80E trans will sometimes not upshift into 3rd. If I power down, start right back up, it will work fine for a couple of days. Changed the filter and fluid, only lasted a month. Anything easily replaced without a teardown? This is my daily driver, with 140K miles.
Old 03-16-2010 | 03:03 PM
chrisbmo2000's Avatar
At 140k you are coming to the end of its "useful" first life....but check all the plugins and wires and look for anything unusual, broken, loose, ect.......also try a complete reset and relearn of the computer...just to see if that helps.
Old 03-16-2010 | 09:20 PM
rcbraun's Avatar
Thanks for the reply. I unplugged all the connectors I could find and did not see any problems. How do I do a relearn? Can I do it with a scan tool?
Old 03-18-2010 | 08:54 PM
A relearn cant be done with a standard scan tool.....undo the battery cable for several hours, and then drive it for about 30-45 min....preferably on the highway
Old 03-19-2010 | 01:48 PM
rcbraun's Avatar
I have not had a reoccurance since unplugging all the connectors, but I will also do the relearn. Thanks for the help.
Old 03-19-2010 | 11:13 PM
Good....you must of had a lose connection somewhere...glad its fixed
tboz89
07-02-2008 11:16 PM
banshman
06-05-2008 05:42 PM
swampdog
05-08-2008 11:49 AM
JakeSilverado
9
01-09-2008 01:41 AM
brianbgboy
07-04-2006 12:04 AM
Quick Reply: 4L80E trans
