87 chevy full size tranny problems
Old 02-02-2008 | 04:27 PM
jaxstas's Avatar
Default 87 chevy full size tranny problems
Engine 350
Tranny 700
4x4
Here goes... A couple of weeks ago I had hesitation going from second to third gear. I took it into a shop and they told me it was working fine. It was and I drove it for a week until today and I know longer have drive or over-drive, only 1st and 2nd.Then while driving it home after I noticed the new issue I heard a ticking noise from the engine. [:'(]That noise turned out to be a bolt from the air pump that had come loose and was hitting the fan [>:], so my question is this... Could the air pump be bad?Could this be causing my tranny problems? []
Thanks in advance
Old 02-03-2008 | 06:06 AM
zimsilverado's Avatar
Default RE: 87 chevy full size tranny problems
My guess is that your 3-4 clutches are out. Time for a rebuild.
Old 02-03-2008 | 10:42 AM
jaxstas's Avatar
Also I took it out for a quick spin this morning and now it is hesitating when talking off, after a few seconds it is fine??? This doesn't feel like a tranny problem. Could these two issues be related?
Old 02-04-2008 | 02:17 PM
jaxstas's Avatar
Default 700R4 Tranny Rebuild
Ok. Having rebuilt engines, replaced tranny's and just been a gear head all my life is buying a tranny rebuild kit and doing the work myself feasible? Having never actually done anything other than remove/replace and changing filter/oil on a tranny I wonder if rebuilding would be over my head???
Ant thoughts?
Old 02-04-2008 | 02:19 PM
stopspazinout's Avatar
Default RE: 700R4 Tranny Rebuild
its a tedious job. easy to mess up if you dont know what your doing. especially when it comes to the ball bearings that run through the runners.
20Sierra01
05-02-2009 09:13 PM
DodgeInfoCenter
11-04-2008 10:18 PM
imlowru
Automotive Parts Wanted
04-17-2008 11:41 AM
houtz007
05-28-2006 05:10 PM
montero91
12-07-2005 02:19 PM
