driveline clunk
Old 11-01-2008 | 11:05 AM
brianj's Avatar
Default driveline clunk
Hello, I have a '94 sierra 4x4 ext. cab short bed. When I come to a complete stop there is a clunking noise. When I leave a stop there is another clunking noise. This only happens at COMPLETE stops. The u-joints are new. I have also recently replaced the rear diff. ring and pinion and all the bearings.It does not appesr to do it when the 4-wheel drive is on. It sounds like there is something shifting forward and backward. The noise APPEARS to be coming from the rear, butyou know how noise can travel. It has done this for years, but now getting worse. Any ideas?? All replies will be appreciated. This has a 1 piece driveshaft
Old 12-13-2008 | 10:50 PM
Perfectdrug 316's Avatar
Default RE: driveline clunk
Mine does the exact same thing. I have a 99 sierra. Anyone know whats going on? Only happens at complete stops then when starting. I have lived with this for quite a while. Have no idea what it could be. I think it does less when towing. I may be just imagining that though.
Old 12-28-2008 | 11:23 PM
bkholt's Avatar
just purchased a 05 Sierra Crew Cab myself and mine is starting to do it also, took my mechanic around the block and he told me it's the "YOLK" or "YOKE", however it is spelled that what the problem is.
he added that GM trucks have had this problem for years.
about 100 bucks will fix it , or there is a packing grease from the dealership that will cure it short term
Old 02-05-2009 | 12:55 AM
ShredSLED's Avatar
Member
same prob here.... on my '02 Sierra Z71
Like there is play in the drive-line when unloaded, then has to take up the slack with a "clunk" when getting on the gas again.
VERY annoying, and even worse than the audible noise is the delay in acceleration! Arrgh!
So, bkholt, what is this magical $100 buck trick your mechanic told you about??
Old 02-08-2009 | 09:18 PM
bkholt's Avatar
mine hasen't gotten bad enough to mess with yet but let me contact him and i'll get back with you
customchris2005
06-06-2010 12:00 AM
bigbrad123
02-16-2010 09:34 PM
garr58
10-31-2009 03:43 AM
GTRMN101
07-21-2006 05:59 PM
fearless_fb
07-16-2005 01:52 PM
Quick Reply: driveline clunk
