Lost brakes, then returned and gone again....
Old 01-14-2014 | 05:04 PM
Th3-Bur8an's Avatar
Default Lost brakes, then returned and gone again....
Hey all!
I just recently bought this 1990 GMC Suburban, got it for a killer deal and it's in need of some things.
Today I was coming up to the stop light and went to hit the brakes, nothing.... Kinda panicked.... pumped a few times all the while lookin at the curb and this guys front lawn, hahaha. Then they reacted, they were fine till I just got to my street and started acting up, again no brakes. So into the driveway and under the hood I went. No leaks, traced lines to and from pump and cylinder. Rubber lines to and from calipers and everything visibly seems fine.
Engine off, brakes build pressure and pedal snaps back fine. Once I turn the engine on, pedal is soft and returns slowly. What are my options here? Anything I can do to determine if it's the Master Cylinder or the Brake Booster??
Thanks in advance for the help and info!
Old 01-14-2014 | 07:53 PM
poncho62's Avatar
Sounds like a bad master cylinder to me.......
Old 01-15-2014 | 09:42 AM
I guess this goes without saying.. but I will say it anyways. As a retired truck driver your truck should be considered UN-ROAD WORTHY until your braking issue is corrected.
As I understand your post, your brakes come and go. (intermittent) I would say your brake booster is on is way out.
Old 01-24-2014 | 01:53 PM
Th3-Bur8an's Avatar
Well, it turned out to be a broken brake line on the drivers side that was causing the issue all along.... hahahaha! Wow.... Oh well! I still replaced the master cylinder, rotors, pads, hard lines and rubber lines. This beauty stops on a dime now!
In2Trux
11-23-2014 08:16 AM
duby55
11-23-2011 07:47 AM
sseeya2001
05-26-2010 12:29 PM
monstertrucker
11-20-2007 08:38 PM
george65
07-23-2007 04:48 PM
Quick Reply: Lost brakes, then returned and gone again....
