Spinning Starter
Old 01-09-2008 | 12:13 PM
ralphmorgan's Avatar
Default Spinning Starter
I have a 1981 GMC 1/2 ton with 305 engine. I use the truck on the ranch as a work truck. About a week ago when I tried to crank it the starter caught and the truck started but the starter kept spinning. I turned off the key but the starter kept spinning. I immediately (let's say as fast as I could) disconnected the battery. I reconnected later and all seemed okay. Then it did it again and I disconnected again. Should I a: replace the entire starter and solenoid
b: only replace the solenoid
Thanks
Old 01-09-2008 | 01:59 PM
stopspazinout's Avatar
Default RE: Spinning Starter
is the key sticking in the start position. sounds more like ignition switch.
Old 01-09-2008 | 03:51 PM
No the key is not sticking. I can turn the key off, the engine stops and the starter just kept on spinning.
Old 01-12-2008 | 12:33 AM
solenoid on the starter.
ted_sager
08-31-2015 03:41 PM
josh250blank
10-27-2009 05:42 PM
Mantonite
07-21-2006 01:52 AM
ted_sager
07-05-2006 07:41 PM
wilber15
11-07-2005 05:39 AM
