torque specs?
Old 09-28-2009 | 04:15 PM
mgibbons's Avatar
Default torque specs?
i need a picture of the torque specs and pattern for a 94 chevy silverado with a 4.3 tbi
Old 09-28-2009 | 10:53 PM
For what part?
Old 09-29-2009 | 11:56 AM
mgibbons's Avatar
for the heads and rockers
Old 09-29-2009 | 12:32 PM
The rockers don't have a torque spec you have to adjust them manually. Hopefully you can make out this picture of the head bolt tightening sequence. I attached a picture of it. Here is the torque spec for the head bolts...
First Step: 25 Ft LBS
Second Step: 45 FT LBS
Third STep: 65 FT LBS
Good Luck!
Old 09-29-2009 | 12:33 PM
Here is another picture...I am not sure which one you can read better.
Old 09-30-2009 | 12:26 PM
mgibbons's Avatar
awsome!! thanks man, makes life alot easier. now on the rockers, some one told me to put the push rods in and then the rocker arm and use two fingers to spin the push rod while tightening the nut on the arm till there is no spin on the push rod then turn another half turn and that should be good. but i was also told to torque them to 20 ft lbs.
Old 09-30-2009 | 04:18 PM
No definitely don't just torque them down. Bring #1 to TDC and adjust as you described above except you want to tighten until you cannot spin the push rod with your fingers and then tighten it an addition full turn. With #1 at TDC you can adjust the following...
Exhaust - 1, 5, 6
Intake - 1, 2, 3
Now rotate the crank one full revolution and adjust...
Exhaust - 2, 3, 4
Intake - 4, 5, 6
Hope this helps! Good Luck!
Old 10-04-2009 | 01:00 PM
mgibbons's Avatar
well i got the valves and **** done and the engine put back together. tried to start it last night and it didnt the starter engages and the motor turns over but the problem is it doesn't sound like it has much compression and i say that cuz the sound the starter makes is a high rpm sound like there isnt much resistence
Old 10-04-2009 | 09:24 PM
mgibbons's Avatar
got it figured out a little more. the valves are all good now but my timing is off well it is but not by much the motor keeps flooding its self out now
Old 10-06-2009 | 09:02 PM
mgibbons's Avatar
ok got it running. whatch out ford boys theres another chevy on the road to tow you away. lol. thankx for all the help
skatafrata
06-24-2011 10:35 AM
Chevycowboy
08-21-2009 11:48 PM
rentrimillos
07-20-2007 09:57 PM
chevy2500in_tx
09-15-2006 04:27 PM
rado2k
04-27-2006 01:15 AM
