transmission actin a fool 99 suburban
Won't shift into 3rd.I changed the filter and fluid and ran some stop slip through it but didn't fix it. Check engine light came on right when problem starrted. Googled it and found that 3&4 shift solenoid could be burnt out, which explains the light bein on. Just wondeerin if anyone else has run into this. Its a 350 vortec with 4l60
the transmission builds up the compression then and cant hold it cause the seal is bad and then it revs real high yea im sure that is your transmission output shaft seal replace that. also dont for get trans fluid and something to catch it with when u take the shaft off from u uv joints ALSO LOOK CHECK YOUR TRANNY FLUID IF IT IS GOOD TAKE IT FOR A DRIVE PARK IT AND LOOK UNDER THE TRUCK ON THE DRIVE SHAFT AREA FOR A LEAK? THATS WHAT MINE DID
cubpak89
8
07-05-2011 07:38 PM
