Report Concerns, Make Suggestions, & Get Help Using The Forum A.K.A. Feedback Section Have questions, comments, or concerns about the website, post them here! NO TECH POSTS
97 chevy z71 brickwall
Old 08-08-2010 | 09:38 PM
97zsilvy's Avatar
Exclamation 97 chevy z71 brickwall
Hey guys,
Got an issue with my ride and am at a standstill. First started with a check engine light which indicates a miss in cyl 3 and 4. Changed out dist cap, rotor, wires, and plugs and still had the light and symptoms of miss/high(1000+ rpm consistently) idle. Seems like a slight miss can be heard from the exhaust as the vehicle is running (no blue or smoky exhaust but leaves a nasty carbon build-up on my trash can) and vehicle stalls when oil cap is removed. After ~200 miles, I checked the plugs again and 3 and 4 were fouled pretty bad with an ashy build-up and possible slight oil contamination. Almost all plugs had slight oil on threads but not noticed on firing mech. and not fouled(except 3 and 4). New fuel pump, o2 sensor, PCV with no improvements.
Possible related symptom of small radiator leak/crack(unsure) which i attempted to fix with a J&B liquid stop leak. Radiator began purging the coolant system through overflow tank until i flushed the tank drain to radiator and it seemed to have slowed the purging. I believe the stop leak settled in the overflow tank and radiator was unable to retrieve coolant from tank.
Any advice on what the culprit is will be greatly appreciated. Next step is compression test...wish me luck.
Old 10-30-2010 | 01:50 AM
auto123's Avatar
Originally Posted by 97zsilvy
Hey guys,
. i think there are two ways in compression test.. manually with a compression gauge, or electronically with an engine analyzer.. You can go for manual compression test..it will be helpful to judge your vehicle...
Old 10-30-2010 | 09:24 AM
If the truck hasn't already had them changed I would change the intake gaskets. They are famous for failing. While the intake is off I would inspect the spider injector in there for cracks or brittle lines. Good luck!
splitz
Vehicles for Sale
11-17-2008 06:59 PM
greggswildlifestudio
09-28-2008 11:45 PM
macmaster728
02-14-2008 02:33 PM
datboyroy12
02-06-2007 11:10 PM
Darrel1
Vehicles for Sale
01-05-2007 03:18 PM
Quick Reply: 97 chevy z71 brickwall
