silverado 4.3 engine not firing on number 5
i replaced intake manifold gaskets because had bad water leak did that ok put all back but missing on number 5 ,had new plugs and leads ,compression test on 3 and 5 both read the same.
hi took truck to garage today for diagonistics only come up with number 5 not working ,he did compression test on 5 and 3 both the same reading,came home took top inlet manifold off and changed number 5 injector to number 3 put it all back pulled plug lead off 3 engine makes a change, pulled number 5 no change ,so it now has new plug and wires,injector changed and still the same i just dont know what to look at ,it has good spark any help please its not loosing water or over heating starts from cold
flipsideafter
16
09-03-2020 08:41 PM
