1995 chevy dually 4x4
Old 01-10-2012 | 09:59 PM
*TATER*'s Avatar
Default 1995 chevy dually 4x4
I am wonder if any one has some ideas on my problem. I have a shake in my front end, only on driver side. I did replace inner and outer tierods on both sides. I check the drag-link, idler arm and pitman arm. Everything is tight. The shake will happen while driving speeds are 30 to 45 then go away. The shake does not stop when I apply the brakes. I did take two tires of the back that were not cupped and stick them on the front. I can put truck in 4-hi and still shakes but not as bad. I do get some clicking from driver side tire while in 4-by. And some times when I go back to 2-wheel the truck will handle better and not shake. Brakes were just replaced and calipers work just fine. I checked ball joints, and wheel bearing does not have a loud humming sound coming from it. I grabbed the cv joint and I cannot move it.
oliverquibble
03-17-2013 09:22 PM
det45
01-20-2013 06:55 PM
Ann6
08-12-2011 05:16 PM
BAM725
Vehicles for Sale
03-30-2010 06:34 PM
obspec
01-23-2008 02:15 PM
