2000 GMC sierra passanger door lock/window problem
Old 02-04-2013 | 08:50 AM
Vic99's Avatar
Default 2000 GMC sierra passanger door lock/window problem
Hi
I have a 2000 GMC sierrra. The problem i have is that on the passanger side door the power lock and window does not work from the passenger side.
From the drivers side i can lock and unlock the passanger side but the window use to go up and down slowly but now it doesnt even move. Does anyone know what i can do to fix this and about how much should this cost? i have changed the passanger side control and it still doesnt work. Plus does anyone know if this has to work to pass a safty? this is my last thing to pass and i cant figure out what it may be.
Thanks for your help.
Cheers
Old 02-04-2013 | 09:20 AM
Check the wiring at the hinge area on the passenger door. From openning and closing over the years you may have broke a wire or two in the protective rubber boot.
Depending on the mechanic whether it passes or not.
You can phone the garage and ask. BUT as a safety feature. if your passenger can't get out in an emergency? That wouldn't be good
Welcome to Truck Forums
Old 02-04-2013 | 11:13 AM
Vic99's Avatar
Thanks for the quick reply Glenn. I will go check that out right now.
Thanks
Old 02-04-2013 | 08:43 PM
RustyFordLover's Avatar
I had to swap the motors out on my 96. The same deal, the driver door was super slow, and wouldn't work half the time, and the passenger one didn't work at all. New motors and they were good as new.
Xware
02-06-2011 08:50 PM
jwad10
10
08-12-2010 11:18 PM
pat63
03-03-2010 09:45 PM
woody1071
03-14-2008 08:58 PM
timbo
03-29-2006 08:16 PM
Quick Reply: 2000 GMC sierra passanger door lock/window problem
