2002 GMC sierra 1500 5.3L EGR valve?
Old 12-06-2010 | 10:43 PM
railroader's Avatar
Question 2002 GMC sierra 1500 5.3L EGR valve?
I have an '02 gmc 1500 with the 5.3L w/ auto trans. I need to know where the EGR valve is located on my engine. It's like trying to find Waldo. I found and replaced my PCV valve. And my other question is how did my fuel economy go from 20MPG or 15L/100KM to nearly 17L/100km from one tank to the next. I keep idling to a minimum and rarely rev it beyond 2500RPM. I think the Egr valve might be the culprit. At least I'm hoping it is since the PCV cost $3 and the egr costs $191!
Old 12-06-2010 | 10:48 PM
Passenger side in front of the valve cover.
Old 12-07-2010 | 08:34 PM
railroader's Avatar
does it bolt on the engine or airbox? I've looked everywhere, I even bought a replacement EGR to see what I'm lookin for.
Old 12-15-2010 | 06:48 PM
railroader's Avatar
found out some trucks aren't eqipped with an EGR and mine wasn't either so it was all for not...thanks anyway
Old 01-15-2011 | 06:09 PM
loast's Avatar
How do you find out whether or not your truck has it? I have a 2002 silverado 1500 with problems symptomatic (rough idle, low mpg - 15 mi/gal) of a bad egr but I can't locate it anywhere to clean it.
Old 03-10-2011 | 01:01 AM
railroader's Avatar
if you see nothing connected to the passenger side axhaust manifold then your truck does not have the egr..
Old 06-03-2011 | 09:45 AM
loast's Avatar
railroader, thank you for you response. after doing some research i found out that GM stopped putting EGR's on the 5.3 in 2002. i hope this thread helps somebody else someday.
Old 06-03-2011 | 09:48 AM
loast's Avatar
by the way, did you ever find out why you're mpg dropped? my truck has never gotten over 19, i was expecting better.
Old 06-08-2011 | 01:48 PM
railroader's Avatar
No it must just be winter gas. Plus a lot more
Gas stations are using up to 10% ethanol which is like burning water
Cause it gets horrible mileage yet costs the same. You can thank the
Government for that! Just keep up your maintenance. From my experience with all the vortec motors.....4.3l gets 10.5l/100km...4.8l gets 12.5l/100km and the 5.3l gets from 14.5l/100km to 16.5l/100km depending on how you drive it. Hope you know metric! And the 6.0l is putting oil companies children through college haha
Old 07-20-2011 | 10:30 AM
loast's Avatar
The first thing i did when i bought my truck was run 3 tanks on each grade of gas and i was surprised to find that regular gas gave me the best mileage. i don't know metric but i will see if i can find a conversion rate.
pukesucker
Silverado/Sierra FAQs
11-13-2014 08:06 AM
95gmcss
04-25-2012 04:18 PM
bfg112
13
07-01-2009 07:42 PM
pear69
02-07-2009 06:30 PM
sueb
08-14-2006 08:07 PM
