4x4 problem please help 2000 silverado
Old 11-24-2011 | 04:11 PM
lavaman2010's Avatar
Default 4x4 problem please help 2000 silverado
I got a 2000 chevy silverado auto four wheel drive push button and we replaced front actuator, transfer case encoder motor, and switch in the cab. We are stumped and cannot get the 4x4 to work at all please help
Old 11-25-2011 | 01:40 PM
LINKXP's Avatar
happened to my dads truck once it was just the fuse but this sound a bit different than that.
Old 11-27-2011 | 10:56 AM
rmck490's Avatar
I'd check fuses as suggested (two total), check the wire harnesses to the encoder motor, have the transfer case control module (TCCM) checked out, and scan for codes.
The TCCM could be the culprit if you don't find a blown fuse or the wiring is okay. A U1026 code would indicate it's not communicating on the serial data bus but may just be offline for some reason which should be diagnosed rather than replaced. A C0550 code would indicate an internal failure of the module and should be replaced with this code. You'll need to have a high-end type scanner (Tech II) or take it to the dealer to have this done.
Good luck and I hope you get it resolved.
Taybox21
03-02-2013 01:12 AM
duby55
10-16-2012 11:41 AM
fallen_angel
02-12-2012 06:01 PM
DOBERDEWD
09-01-2010 01:05 AM
chevyguy
09-29-2007 12:02 AM
