Engine miss while driving in wet weather
Old 01-06-2010 | 01:49 PM
valveguy's Avatar
Default Engine miss while driving in wet weather
My '00 Silverado has developed a miss in humid or wet weather when in 2nd, 3rd or 4th gear above 2000 rpm. This just started and I was wondering if anyone has experienced this problem. The truck has a 4.3 V-6 with a 5 speed manual transmission. It is a C-1500 SWB regular cab 4x2 with 150,000 miles on it. The truck runs fine in clear/dry weather.
Old 01-12-2010 | 03:23 PM
mjn030's Avatar
Have you tried checking the timing or swapping out the distributor cap and rotor ? It's quite possible that they are starting to wear....
Old 01-11-2011 | 11:32 AM
riderrich's Avatar
Default miss fire only with lights on and wet outside
My 1985 gmc sirra runs very bad to the point of stalling at cruising speed only with parking or headlights are on and mostly when it is wet outside. I have changed out o2 sensor distributor sensor and fule pump but still runs bad. I believe its all tied into the ignition or light switch still serching
Old 03-16-2011 | 05:04 PM
Moomba's Avatar
do you happen to hear a loud squeal when this happens? could be belt slipping.
Old 03-24-2011 | 06:44 PM
valveguy's Avatar
No such noise. I recently purchased a distributor cap, rotor, plug wires and plugs but haven't installed them yet.
Zenman
01-04-2012 11:24 PM
highroller152
04-01-2009 01:34 PM
hmcgary
09-17-2008 06:21 PM
chev.half
11
06-14-2007 11:51 AM
careflitemedic
08-26-2006 04:11 PM
