Toyota Tundra Discuss the Toyota Tundra here.
2003 tundra
Old 02-24-2010 | 03:02 PM
flounder's Avatar
Default 2003 tundra
I 'd like help with replacing the evaporation control cannister that is located near the gas tank of my 2003 tundra. Had the one replaced that is in the engine compartment and need to replace the one that is near the gas tank. main question is do i have to remove the gas tank to replace it? and where can i purchase one online??
Old 04-28-2010 | 06:49 AM
aja72's Avatar
Banned
Fuel vapors that are stored in the canister. The vaporized fuel must be vented. On uncontrolled are purged as the throttle is open after the engine is vehicles, fuel vapor is vented to the atmosphere through started. The vacuum at the purge line causes fresh air to the gas cap and the idle vent (para 4-14). The discharge enter through the bottom of the canister. The filter keeps of these vapors to the atmosphere no longer is foreign matter from entering the canister. As the air acceptable on automotive vehicles. As a result, all passes through the charcoal it removes the stored fuel currently produced vehicles are equipped with a fuel vapors. The vapors then are drawn into the carburetor evaporation control system. through the purge line, where they are reburned.
Valk97
08-23-2012 01:42 PM
silverstrk65
08-25-2006 04:05 PM
grego37
06-17-2006 06:46 AM
rick
06-12-2004 01:37 AM
